Hi, I'm trying to restrict the torque converter from locking up in 2nd and 3rd gear under any circumstances, part throttle or wot.
Also in the 'Unlock' tab, do I make the TCC Release Threshold a lower rpm at heavier throttle positions?
So if it does lock-up, I can command a low rpm that it will always be above, so at 45% tps for example or greater, it will be unlocked above the rpm I set as long as tps is above 45%? My understanding of this quickly so far.
I tuned out my tcc lockup in those gears as well. Just maxed out all lock tables, i think there were about 6 for every gear? I left the unlock tables alone just in case it would lockup. I only have lockup in overdrive now. Anybody know why there are so many tables for each gear and what each one means?
