Anyone able to get 6l90 ZL1 tcc pressure higher than 110 psi? I'm commanding 150 and 110 is the highest I get in the scanner. Max pressure is 150 and the desired pressure table is 150.
You're only seeing an inferred pressure which is a transfer function based off the solenoid amps.
You can raise line (increase virtual torque) as that feeds the converter circuit. There is a TCC pressure limit valve in the circuit so you'll only get it so high.
