Results 1 to 5 of 5
Thread: 2007 chevy suburban 5.3l w/ dod and flat top pistons
    Oct 2021
    New mexico, southern
    6
    my 5.3 is burn oil and blow with smoke exhust. does somebody have a good tune for this type of build?
    13,565
    A tune won't stop the engine from burning oil if it's already that bad.
    Turning off the DoD within the tune will probably help some but you'd need to pull the engine apart, hone the cylinders and put in new piston rings to really stop all the oil burning. Probably will want to inspect the pistons for wear too and upgrade to the new updated driver side valve cover for the PCV problem.
    Oct 2021
    6
    i did a long block on it.
    13,565
    Well you didn't really explain that in your post. You just said it burn oil and smokes.
    7,649
    All 5.3s used in 2007 Suburbans were 9.95:1, which means flat tops with 243/799 heads. If the engine you burned up had dished pistons then at some point somebody put the wrong motor in it.
