Results 1 to 10 of 10
Thread: Assistance with weak acceleration/torque seems at all RPM ranges
    Nov 2019
    6
    Hi,
    2011 Camaro 2ss, LS3 (swapped out l99), 6l80E, Stage 4 CAM, Ported Heads, CAI, Long header, SummitPro TC 3200 stall (single), 4.10 ring and pinion gear, 29.3 tire size rear, everything else is stock.
    This was originally a Mail order tune.
    Issue: acceleration bogs engine down anything above a very slow and steady acceleration. I cant really get on the throttle. Overall issue seems to occur regardless of RPM. Lastly, transmission will creep up to trans idle overheat.
    I have attached my tune and a log of general info. I do not have wideband. I am happy to log more useful information for any of you experts I would just need some guidance how to set up what you need to complete the picture i.e. PiD.
    Anyways before committing to a full blown I figured I'd throw it out there to see if you guys and gals can discern what might be wrong, suggestions, to get my car accelerating normally.
    Attachment 118913Attachment 118914
    Thanks in advance.
    Tuner MakesBadDecisions's Avatar
    Oct 2017
    Montucky
    194
    Diagnose and repair the code P0442 - Evaporative Emission System Leak Detected (small leak) (Current)
    You are not logging close enough to see a full picture. Load this channels list up and get a log of start up and idle for 2-3 minutes and then go for the same drive as you did last time, when you get home let car idle for another 2-3 minutes to capture some data. Post that log and along with the tune that is in the car currently.
    You WILL need a wideband to get WOT fueling accurate
    2017 Crew Short 4x4 - 575hp/581trq at the tire
    2017 C7 GS 3LT - All stock for now, waiting impatiently for shop time to install parts
    13,565
    Whoever is offering a mail order tune for a combo like that shouldn't be doing business. It's impossible to predict all the changes that a vehicle will require.
    Nov 2019
    6
    Quote Originally Posted by MakesBadDecisions View Post
    Thanks for your help. Will do today or tomorrow.
    Nov 2019
    6
    Follow up question
    How do i load your xml file into scanner?
    Oct 2017
    Montucky
    194
    save the .xml file to the This PC/Documents/HP Tuners/VCM Scanner/Channel Configs folder.
    Tuning Addict
    Jan 2015
    6,813
    You know - first off why? Why did you swap out the l99 for a ls3? Was it just because of the initial power numbers or was the l99 having problems? Only reason I'm asking is that's part of your problem.
    There are only 3 main differences between a ls3 and a l99. L99 has variable cam timing and because of this it has reliefs cut into the pistons to allow for the extra valve clearance causing a drop in compression ratio. The ls3 has a more aggressive cam from factory which is ALL that really gives it it's extra hp and tq. Me personally I would have rather had the reliefs and kept the l99...
    Now with that being said this should have turned the lightbulb on for the two different tunes. LS3 doesn't have variable cam - your tune still shows variable cam present just for starters.
    ~Greg Huggins~
    Nov 2019
    6
    Very helpful. thanks for taking the time to review and more important, catching that issue.
    Nov 2019
    6
    Thanks, will do so. log to follow shortly.
    Nov 2006
    2,742
    This needs more tuning but the issue looks like a miss on the drivers side. I could tell better if you logged a wide open throttle pull.
    Tuner at PCMofnc.com
