Originally Posted by
madkidd007
make sure you have the correct info installed for the injectors and the map. Your running various parts from different vehicles based on a Tahoe tune. Honestly you would be fine with running a 07 tahoe MAP sensor and probably tahoe injectors given this is a NA build. If your set on keeping these parts you'll need to go on the repository and find the correct info for the parts you are using. Which shouldn't be to bad considering you are using GM parts.
For spark I would use the LS2's file.
