Results 1 to 9 of 9
Thread: Looking for a tune
    Tuner in Training tryNto's Avatar
    Mar 2022
    12
    Looking for a tune
    Is anyone still active that is tuning for a 2003.5 HO 5.9 with an NV5600?
    Looking for a small HP or a tow tune to use as a comparison to what I'm working towards.
    TIA
    2003 2500 QCLB 305/555 NV5600 W/ FAST COOLERS w/ 9 qts Pennzoil Synchromesh, 4x4, Edge CTS for Gauges added with EAS a real Oil psi, LP psi, Oil temp and trans fluid temp, DPP Cool Hose w/ OEM AF Box, Baldwin PF7977, GDP MK-2 FF Kit, OBS Fan Clutch Mod, Steering Box Brace, 1 piece Al driveshaft, On-Board Air w/Horns, BedRug under Color Matched Leer topper.
    Nov 2020
    11
    Add in 20-30% fuel map and run around 24Deg timing at the top. Normally hyped up trucks go as far at 32-38Deg timing. the 20's is a safe start.
    You may need to pull Current(amps) from the FCA if you see rail pressure dropping on the logs.
    Advanced Tuner dhoagland's Avatar
    Jun 2015
    Aubrey TX
    568
    Here are 2 that I downloaded from here a few years back...
    Mine is an Auto so I'm not sure these will work (I think they will as I believe the TCM is stand along)...
    Anyway you can compare these to a stock read and get an idea what has been done
    Jun 2015
    Aubrey TX
    568
    Stock Read from my 03 Auto
    Mar 2022
    12
    Thx for the replies.
    Apr 2022
    Quote Originally Posted by dhoagland View Post
    Where did you download these files from? When I look in the tune repository there's only like a handful of tunes in there and most of them are stock.
    Senior Tuner Jim P's Avatar
    Jan 2018
    Everywhere
    1,643
    From the forum, not the tune repository
    Apr 2022
    Quote Originally Posted by Jim P View Post
    Oh, that's weird. I can't find any with the search tool. I was trying to find the ones link in this thread so I could read what they were intended to be doing.
    I believe I PM'ed you about a week ago to ask whether you're still tuning transmissions. Not sure if you saw that message. I appreciate your time.
    Jun 2015
    Aubrey TX
    568
    Quote Originally Posted by Brew View Post
    I tried to find the original threads but I could not...
    Its very possible I found them on Cummins forum but all my subscribed threads are gone (I did let my membership expire)
    If you compare the 2 to the stock read I posted you can see what was done
    They were threads just like yours, wanting a safe power increase
