I've been working on a tune for a 2005 corvette, H/C/I car. This is a e40 ECM, one year only.
In MAF the mode, the idle is a little rich, about 13.8, the tip-in response goes lean for a few seconds, and then the AFR goes in the mid-12s to high 13s depending on load and RPM.
My MAF tune was pretty close to spot on, slightly rich from 2350 hz to 8200, from 0 to 3.1 rich. Only two spots of slightly lean (0.3 and 0.4 respectively).
See #25 log file. The tune is also #25. The VE table is from a mostly rich SD tune I did with same car last fall.
All I did was to change the MAF Freg Fail High to get it into SD mode.
The SD mode is tune # 26 and the log is 22-04-04 14-19-02.hpl.
With the engine in MAF mode, the AFR was 13.8 and with it in SD mode it was 15.6.
I was scared to drive the car so I changed it back to MAF to drive home.
The MAF only log showed the VE variances to be pretty good.
What is going on?
Smart people help please...
Dave
