1998 black box, under power enrich there is a tps adder - this table adds to base afr in relation to throttle position. It is generally used to lean the fuel at smaller throttle setting. On the graph it is ?eq ratio subtractor? . Because of being a subtractor if I enter 1.1 would it change the afr to 16.17. There are currently all zeros in this table.
