I just recently did timing chain tensioners and a valve job on my B8 2.0T, I noticed the car had imrc blanks installed and to my knowledge was never tuned, car fails to start and only sputters when it tries. Any advice?
Did you have the issue right after doing the Timing chain? you saw the blanks when you took the intake out for doing the timing chain so it was running before or?
The car should still run i had mostly issues in cold start but once the cycle went thru car was running fine.
Sorry for the late reply, it ended up being a fuel line being partially disconnected and leaking most of the pressure. It does still have the rough idle on a cold start but nothing I can't touch up in the tune I'm sure.
