so like the title says... first time tuning anything...I own a shop and do anything automotive so im familiar with the logistics of mostly everything, but tuning has me a little overwhelmed.
What i have going is an 01 tahoe that had a junk 5.3l (LM7) and i put an LY6 out of an 08 in it ... it runs pretty decent but i know theres massive amounts of adjusting for improvement.. Im just not experienced/confident enough to know what to adjust without potentially hindering anything
it has the stock trans (4l60e)/torque converter, t-case, tire size, O2 sensors, MAF, valve train, ECU, resonant knock sensors (with aftermarket brackets)...all stock per vehicle application..
stock LY6 parts consist of: original intake/injectors #12580681, MAP sensor
other upgrades when built was a ls3 cam #12623063 non VVT
Dur.@ .050in. 204/211
Lift - .551 / .552
Lingerfelter conversion module
92mm throttle body ...cable driven
no egr with LY6 ...im sure your aware
just really looking for pointers on where to go from the little bit ive changed / or if someone can build a base tune and instruct me where to go from there... ill pay.. if youre not having me pay your mortgage that is... have original stock file for both the LM7 and LY6 vehicles if that helps at all... tell me how dumb i am and what ive done wrong ..not gonna hurt my feelings..i get it.... just trying to learn and get this running better where its happier.. this is the current tune file im with and changed very little. just a little obvious things (to me)...... any help/ insight would be greatly appreciated
Thanks, Andrew
