ok, lets look over these timing tables, I have zero (0) in all the tables where I am running into boost, and all the multiplers at 1.0.
I understand my wide band reads 13-14, but the gauge and the AEM preset are about 1.2 off, and the sensor is about 6 month old bosch so those readings are incorrect. The actual AFR is about 11.5-11.7. Having said that you would think anytime I would be in the
HO (pe), LO (pr), HO (pe) alch, or LO (pe) alch, I should be running ZERO timing..... well lets look at this..
we were trying to pull timing and noticed that none of the numbers added up, so either you can't actually change the timing or I missed a window somewhere, could some one please enlighten me, thanks,
-Garrett
