Installed an ON3 turbo kit, Fuel Injector Clinic 85lb injectors (data is correct), GM 3 bar map, MAF is failed, I have added Base Airflow,Set idle at 750, adjusted the VVE table multiple times and it's pretty close and still not getting the results needed. Followed TTS book, only issue is they do not give much help in the book beyond that. I have tuned several cars/trucks NA and with power adders and haven't ran into this issue on SD that couldn't be worked out. Any advice or help is greatly appreciated. I am missing something!!!
