I've seen this happen on numerous (3 or 4) customer vehicles in the past and just figured it was a bad Manifold Air Pressure sensor.
Recently: No crazy combo. I have a bone stock customer LT1 with a simple TorqHead conversion. Upon 100% throttle the MAP comes up to 90kpa very slowly and stays there for a while but 1/2 way through the WOT it starts diving down from 90kpa to 30kpa. (30kpa at 100% throttle...think of that).
Anyone else see this? Do you think it is in anyway related to internal wiring of the TorqHead PCM? On the LT1 PCM the MAP shares the 5v return to the PCM with ECT and Trans Temp. On a true stand alone P01 ECM the MAP 5v return is independent and has it's own pin into the PCM. TorqHead PCM is not a true stand alone PO1 ECM. It may have internal wiring to the PCM that works, (most of the time). I'm thinking some subtle wiring problems and or grounding.
Discuss.
Thanks,
Karl Ellwein
