Originally Posted by
DB5249
Neural Network will be disabled, cant get a data log if the truck won't run more than a few seconds. i already had to fix the can wires between C123 and C130 just to get it to read ecm. its an offroad long travel truck. GM and fords, subi, polaris, can am are my specialties, stock injectors are 42lb and from what I can find 6.4 injectors are 44lb, not a huge difference and you would think the truck would be within a 30 percent spread on the ve table. its a new build and was miss firing with a tad bit of rpm running, 2000 rpm range. pulled plugs some fuel saturated some not. he attempted to run it before I had the chance to help him out. i am going to verify power at all the coils, clean and gap plugs, and go from there. it would be nice to have injector data as stated this should be a common simple swap.
