Results 1 to 7 of 7
Thread: 2020 tt gt 2 step fuel cut
    Intermittently when I use my 2 step the car will go into injector cut.
    Last night I made one attempt (2nd log) and it worked great. 30 minutes later I tried again and got an injector cut.(1st log)
    2020 Mustang GT On3 Low Mount Twin Turbos. 10R80 Trans. Holley Intake manifold. Brisk 2 step colder plugs Gapped at .022.
    Tbrake Fuel cut.hpl
    JAMES GEN3 VV..001 new intake, old tune 10.3, 7700, wastegate maf, idle changes.hpt
    **UPDATE: I found the log from where the transbrake worked without cutting fuel. Bare road no prep, lots of tire spin, but no fuel cut.
    Good Tbrake pass.hpl
    Oct 2016
    Poland
    1,750
    if you want to buy a good base tune feel free to email me directly...
    Jul 2019
    9
    What is your 2-Step RPM set to?
    2-Step needs to be above this value:
    Tuner barkingspud's Avatar
    Mar 2006
    NW Burbs of Chiraq
    119
    Quote Originally Posted by 5OHMG View Post
    You mean 2-Step should be BELOW that value.
    Oct 2016
    Poland
    1,750
    Quote Originally Posted by barkingspud View Post
    No, above as this is max rpm at which coil test will be performed.
    Mar 2006
    NW Burbs of Chiraq
    119
    Ugh...Yes. 2-Step set for 2500 RPM, Coil Test Set at 2000 RPM... I stand corrected.
