Results 1 to 9 of 9
Thread: hesitation on takeoff
    Jan 2021
    Miami
    351
    im noticing hesitation when leaving from a stop. the car motor tries to rev but it breaks up and no movement till the throttle v gets to .45
    at idel the voltage reads 0.0 so from o.o to .45 its breaking up and no movement, once it does move, its a scalded cat and have to feather the pedal to help with the jump. 9any suggestion on where to look? thanks in advanced.
    By the prickle of my thumb something wicked this way comes!2008 Chrysler 300c! 2013 heads/220/230 comp cam/LTheaders/FTI 2600 stall converter.
    Mar 2021
    Pompano Beach FL
    261
    any knock what about tip in?
    www.n2speed.com
    http://www.amp4x4.com
    [email protected]
    Dodge And GM Tuning Suppport
    Diablosport CMR | HP Tuners
    Nov 2019
    227
    Be a lot easier to try and diagnose if a thorough datalog of the issue is supplied.
    What are the AFR's/fuel trims doing?
    Jan 2021
    Miami
    351
    Quote Originally Posted by HaasExp View Post
    greetings. today ill be able to take car out and create a log.been stuck in bad for a little. as of now i have o2'2 disabled because both upstream are bad. i in open loop.this has been happening for awhile now.thank you guys for responding. ill have that log later today.
    Jan 2021
    Miami
    351
    Quote Originally Posted by N2speed View Post
    no knock and not sure what the tip in does but its disabled.ill have that log later today.
    Jan 2021
    Miami
    351
    here is the tune
    Jan 2021
    Miami
    351
    sorry about the delay, i just notice you asked for the log and not the tune.
    Oct 2021
    Allentown PA
    363
    Quote Originally Posted by Turbo2gnx View Post
    so from time stamp 0:00 to roughly 3:00 that's a log of your car just idling ?
    62 Biscayne 425/409 SS/D stock class car 10.60s
    66 Dart 426CIG3 8.60@171 2750lbs Naturally asperated
    04 Ram All Alum , 468Ci G3 10.50s @4800 lbs Naturally asperated
    04 Rumble Bee, built 6.1 ,4000lbs 10.48 @ 129s MPH. Naturally asperated
    05 Rumble Stock 5.7, 3.92s TUNE ONLY 13.94@98mph
    Jan 2021
    Miami
    351
    Quote Originally Posted by rays04gtx View Post
    i apologize for that but after that 3 mins of idling,it gets up to 3rd gear after. did you see that or no? if not ill send a different log. thanks again for replying.
