Results 1 to 10 of 10
Thread: What am I missing? PCM commanding a .31Eq but I'm commanding .85Eq in PE
    Mar 2020
    380
    This one is blowing my mind. Currently I am working on the MAF table. Just finished the OL with PE off part throttle, turned on the PE set at 1.176 but when I blip the throttle to see if PE activates, it commands a .31eq and bogs like hell
    2001 Sierra 5.3 RCSB
    Stage 3 High Lift Cam
    BTR 660 Springs
    Trunnion Upgrade
    LT Headers to a 3" true dual setup
    42lb Gen IV injectors
    Holley High Ram and Holley 105 TB
    This truck has a stock tq converter, so it is idled a little lower than I would like, but it's how it showed up...working around it
    2001 Sierra Stg 3 High Lift and 42lb injectors.hpt2001 Sierra Idle and Revs log.hpl
    Mar 2020
    380
    Anybody with any ideas?
    Apr 2020
    11
    do you have the log so we can see whats going on? you could try to stair step your PE table. you have it set for the entire rpm range. try having it gradually getting to the desired PE value. have you set your pe and then tried tuning your VE, then tuning the maf?
    Jan 2014
    SoCal
    1,557
    What is going on with the open circuit B2S1?
    7,578
    Might want to take another look at Power Enrich - IAT Adder and Open Loop/Base - PN/Drive Enrichment - Initial Adder vs ECT. Those should be close to or equal to zero, not 1.00.
    Quote Originally Posted by TheMechanic View Post
    Forced open loop, guessing wideband installed in place of B2S1.
    7,578
    Just a quick note...
    Setting to 1.0 disables a multiplier table. Setting to 0.0 disables an adder table.
    Mar 2020
    380
    Squirrel you probably found it there then. I figured anything times 1 is itself.
    Yes, the WB is in B2S1
    Mar 2020
    380
    Problem solved, and just confirmed.
    In the ECM 12402 Power Enrich Fuel IAT Adder Table... Setting the table to 1's will cause extremely wacky stuff. Set to 0, now it will command a .85 when you go WOT on the pedal
    7,578
    But those tables add, not multiply. Those two (and maybe more, you need to re-check anything you fiddled with closely) are set up as if they were multiplier tables you wanted to turn off.
    7,578
    Quote Originally Posted by village_idiot View Post
    Cool
