Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
Thread: MAF [lb/min] Pegged, But Period Keeps Decreasing, Air Load Rising?
    Senior Tuner CCS86's Avatar
    Austin
    1,089
    Quick update:
    The real issue here was insufficient fuel supply. The dual DW400s were not enough, the hat configuration was not ideal, nor was the tee splitter in front of the rails.
    Now with a better hat, triple pumps, and wye splitter; all the MAF curve increases are backing out.
    I think the dead give away here was that when it started going lean, the injector PW was rising relative to air load. Once the boost flattens out, your PW should as well. Fuel flow rate obviously rises with RPM, but PW should stay locked to trapped airmass.
    I'll post an after log soon.
    Oct 2016
    Poland
    1,744
    Quote Originally Posted by CCS86 View Post
    Quick update:
    what i told you?
    Oct 2016
    Poland
    1,744
    Quote Originally Posted by decipha View Post
    thats the maixmum airmass limit of the ecu
    you have to scale the tune back
    Not true actually, ECU can keep way higher, that is a limit of ODB bit rate...
    Austin
    1,089
    what i told you?
    Yes, shortly after I said that I thought fuel pressure was dropping, you also suggested the fuel system was falling behind. Both our suspicions were correct.
    I don't think it is a bit "rate" issue, but rather a variable type issue. Either way, it's a display issue, not affecting the important calculations.
    Oct 2016
    Poland
    1,744
    Yes, shortly after I said that I thought fuel pressure was dropping, you also suggested the fuel system was falling behind. Both our suspicions we're correct.
    86lb is a SAE PID limit for airflow - fo sho m8...
  6. #26
    Jan 2013
    Hawaii
    2,101
    You can only count so high, using 16, 1's or 0's.
    16 bit channel display limit. Grams per second you'll see the number 655.35 or whatever 2^16 is.
  7. #27
    Austin
    1,089
    Quick update:
    The primary issue was definitely a lack of fuel supply, and the PCM is perfectly capable of calculating and fueling without any "scaling" tricks.
    We aren't done yet, since there are some tensioner issues to sort out. But, we are very much back on track and I am slowly pulling out the MAF curve corrections entered to compensate for the undersized fuel pumps.
