Hello Folks,
First post here.
I have a 21 LT1 and am swapping over to flex fuel. Have installed the sensor and work as a GM Engineer so good there
Question: Where does the Mult4 table come from below? I have looked in both the internet and this forum and nothing to compare to.
Thanks in advance!
Erick.
EFI Tuning LLC
Tuning Tool: HP Tuners v3.2.x
Platform: 2016 Camaro SS
File: 2016_ss_flex_fuel_baseline.hpt
Changes:
*** required ***
- modified Engine -> Fuel -> General -> Air Fuel Ratio -> Stoich AFR-> Flex Fuel AFRs
- modified Engine -> Fuel -> Open & Closed Loop -> Flex Fuel -> Flex Fuel -> Enabled
- modified Engine -> Fuel -> Open & Closed Loop -> Flex Fuel -> Flex Fuel -> Fuel Sensor -> Sensor
- modified Engine Diag -> DTC's -> P0178 -> Flexible Fuel Sensor Circuit Low -> checked, Error Mode -> MIL on Second Error
- modified Engine Diag -> DTC's -> P0179 -> Flexible Fuel Sensor Circuit Low -> checked, Error Mode -> MIL on Second Error
- modified Fuel Sys -> Diagnostics -> Flex Fuel -> Sensor Diag -> Enable
*** optional ***
- modified Engine -> Spark -> Advance -> Spark Correction -> AFR Correction -> Alcohol -> Gas table
- modified Engine -> Spark -> Advance -> Spark Correction -> IAT Spark -> Mult4 -> [1.00 1.00 0.80 0.50 0.20]
- modified Engine -> Spark -> Advance -> General -> Cranking/Start -> Cranking -> enhanced for Flex Fuel
- modified Engine -> Spark -> Advance -> General -> Cranking/Start -> Alcohol Adder -> timing added for Flex Fuel cold starts
