Results 1 to 3 of 3
Thread: E67 Engine Swap to IV Gen ECM
    Apr 2022
    2
    My new Project is a 78 El Camino. I have a Chevy 350 that I built several years ago and will re-freshen it as the bases of my new build. I also have a TPI system that I will update with EFIConnection hardware on this build. I plan to run a 4L60E ungraded to 4L75E specs. I would love to swap-in a late model dash, say from a 2015+ Camaro. This would more than likely require a BCM swap as well.
    After looking at the different ECM options, I'm planning on using the E67 ECM.
    I guess after looking at everything and searching over the forums, my questions have to deal with the VIN.
    Will I be able to program this using the El Camino VIN? I also realize that if I swap in any Canbus Dash electronics, I will need to program them with the correct/matching VIN as well.
    Also how will this work with the licensing procedures?
    Thank You
    Billy
    Apr 2022
    2
    Also, what would be the best Vehicle Tune/OS to start with?
    Billy
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,265
    You will NOT be able to program your E67 ecm to an El Camino vin number using our products. You would need to first find a solution for that.
