My first shot at tuning would appreciate some feedback before I flash it and work on it from there. thanks. Megacab Tune 1.hpt the truck is all stock with a g56
post up a log, SOI max should be raised up 32-36 range for your needs might be ok but I raise them all so if you bump to a real spicy tune it's done.
wastegate min duty take that up 40-80%
max rail 170-175 mpa
you'll need to watch rail psi and likely adjust base dc in the pump
main timing I like to run more negative in spool up
and as well I run less pilot timing up high
looks like a good start
2010 F-350 03 5.9/848ecm, built 5R110, 30% over sticks, 10mm pump, 64mm Stealth Turbo
2008 F-350 03 5.9
Fumminstuning.com
Alrighty I’ll try that and get a log posted. Thank you
