Page 1 of 2 12 LastLast
Results 1 to 20 of 34
Thread: Gen 1 coyote LU47 tuning help !
    Hello Guys i'm new in Tuning World , so i did my tune via myself
    car model : 2012 Mustang GT 5.0
    Mods : Pmas tune req CAI , Boss Im , LU47s , VMP bap , Kooks LT with x pipe , Borla catback , Oem spark gapped at .045" , 3.55 rear end
    After Loading my Tune and start the car it stalls and TB not responding then she shuts down by her self
    NO CEL shows in scanner
    attached is my tune
    any help guys !
    Oct 2016
    Poland
    1,712
    You realize there are TWO types or 47's?
    Feb 2012
    TEXAS
    631
    Quote Originally Posted by voodoo tuner View Post
    attached is my tune
    any help guys !
    Your data is correct for LU47 3bar. I attached the Maf data provided by PMAS
    47# [M-9593-G302]
    47# [M-9593-LU47] 3-bar
    47#[m--9593-LU47] 4-bar
    Nov 2009
    All Around
    3,149
    injector data looks weird
    Feb 2012
    TEXAS
    631
    Lu-47 4-bar basic data
    Quote Originally Posted by mstang_man View Post
    47# [M-9593-G302]
    the Maf data in the file is confused me so i use another pmas car data attached is my change in maf vs period
    can you send the tune please so i can change the ( flow rate low mult vs pressure , high , breakpoint mult ...etc )
    doing multi changes on the tune all the Night now the car fires right up and drives well without any issues , after doing some idle and rev and cruising logs seems like O2 sensor bank 1 , sensor 1 is waay off also this DTC shows up P2626 , so i'll change the 02 sensors and continue from there
    attached is the current tune
    Feb 2012
    TEXAS
    631
    Url link is for 47lb injector 4bar which is stock on Roush stage 1
    https://forum.hptuners.com/showthrea...ht=roush+stage
    I see it’s for Gen 2 coyote can i use it in Gen 1 ?
    Feb 2012
    TEXAS
    631
    yup
    attached : WOT pull datalog first thing i notice is STFT VS Maf period Table is all blink so there's no Maf corrections that must used on the Tune ?
    second thing the commanded Lambda is .82 , WB bank 1 and 2 shows from .83 to .85 is there Any Corrections i should do ?
    the Timing is around 21.5 degrees it's okay i've pulled -3 of spark i don't want any detonation on the first WOT pull
    the Rev Limiter is set as stock 6900 RPM idk why i have set it to 7500 rpm from ( Engine >Fuel>Cutoff , DFCO > Cutoff and Neutral Cutoff set at 7500 rpm )
    also
    Trans > General > by gear from 1 to 6 all of them set at 8K RPM
    Also i have Zeroed all the tables on MAF Temp Comp to dial the MAF on those logs
    Notice : I have Turned LTFT off on WOT pull
    Attached : WOT pull with LTFT back on and set the Adder global spark back to 0
    Feb 2012
    TEXAS
    631
    MAF Data from your data logs
    Is this the Average?
    Feb 2012
    TEXAS
    631
    STFT + LTFT =Averaged each are individual charts per datalog
    attached a screenshot of both of LTFT+STFT and all of them shows as blank how i can get the values
    also i see in your screenshot the values of maf Row Axis is different than mine why ?
    this is my Row Axis pulled from my tune
    83.3 85.4 89.2 93.5 98 102.9 108 113.4 119.2 125.1 131.5 138.5 145.9 153.9 162.1 171.7 181.5 192.8 205.4 218.4 230.2 244.5 260.7 276.9 293.9 308.5 327.1 340.2 357.6 377.1 402.1 440.9 495.5 589.2 652.4 706.7 751.1 809.8 883.2 1439.5
    Feb 2012
    TEXAS
    631
    your Row axis applied to my STFT+LTFT
    that's strange idk why it's shows on my VCM scanner blank values
    is the reason that my VCM Scanner is Beta version ?
