Results 1 to 15 of 15
Thread: Is it Supported? 2005 Chevy Classic, 2.2 L61
    Is this car supported???
    2005 Chevrolet Classic, 2.2 L61 (Not Malibu Classic, just.... Classic)
    This car is an odd duck. It's basically a 2003 N-body Malibu that was built in 2005 and intended for fleet-only sales. I'm guessing it was a rental car. The engine is definitely a 2.2 L61 per the VIN. Guessing the trans is a 4T40, but I haven't verified that yet. It is definitely NOT a 2005 Epsilon-body Malibu. The Supported Vehicles list includes the 97-05 Malibu 2.2. But it doesn't list the 2005 Classic 2.2 L61. And I'm not sure if there's some gotcha that makes the difference between the two.
    So, can this turd be tuned?
    Thanks for your help,
    Dr scott Diabolical
    current owner of the car Motor Trend called "Less sexy than a wet Tuesday afternoon in Cleveland"
    ...because I inherited it. And because it's beige. And because it would be fun to tune the most boring car ever made.
    13,564
    It's still malibu even if they called in a classic. The parts catalog at one of my jobs just lists them as Malibu Classic or Malibu, with the Classic obviously being the 1997-2004 body style.
    The vehicles list does say both 97-03 and 97-05 which would include that 2.2 for 2004-2005 model years. Do you have HP Tuners yet to plug it into?
    I don't have a tuner yet. I'm trying to confirm that my car is supported before dropping $$$.
    It "appears" that in 2004 GM kept building the 2003 N-body, but called it the "Malibu Classic" They released the new Epsilon-chassis as the "Malibu" sometime mid-year 2004. BUT.... they kept on building the N-body car, calling it just "Classic" for late 2004 and 2005. Those were probably cars made from the leftover 2003-04 N-body parts. My '05 interior and engine layout appear identical to the 2003 Malibu. Which is also probably why their sale was limited to fleets and rental companies when they were new. Floor sweepings and leftovers.
    Aug 2016
    386
    Can you post a picture of the ECM ?
    This is the best photo I could get tonight. I'm not sure how the silly thing comes out of it's holder and I didn't want to start prying on things in the dark.
    Update: After a bit more digging... this appears to be a P11 ECM, similar to the ones used in the 2005 Cavalier/Sunfire 2.2 L61s. EFILIVE lists the 2005 Chevy Classic by name and references the P11 as its ECM. And, I've found a few sites that cross-reference the GM part# 19210073 to the 2005 Classic, 2005 Cavalier, and the 2005 Pontiac Sunfire. So maybe, just maybe.........
    Any J-body tuners out there?
    Your thoughts/experiences ?
    Here are the RPO codes in case they help. I was able to decipher most of them. It definitely is an Ecotec 2.2 L61 with a 4T40E NM4 transaxle and a 3.91 final drive ratio. So that will be the limiting factor in how much power I can add. The 4T40E is supposedly rated for 190 lb/ft and a 4,000 lb vehicle. IDK if I can get anywhere near 190 ft/lbs with just a tune though. But if I can, that should theoretically be enough to get me in the 130 mph Club at Bonneville.
    Aug 2016
    386
    Yes, that's a P11. The question is whether the operating system / calibration is supported.
    Gotcha. Based on what I've gleaned from the EFILive website, this P11 should use the standard GM operating system. So the real question is: Does HPTuners have a calibration file for this car? Any idea how I would determine/confirm that? Is there an appropriate HPTuners support desk where I could ask this question?
    1,459
    What do you mean by calibration file? HP Tuners does not supply modified tunes/calibration. It only supplies the interface and software to allow a user to make changes. It will read your existing "calibration" from your ecm as a starting point to make changes.
    Aug 2016
    386
    I think he's looking for a solid answer on whether this application is even supported before making a purchase decision. The PCM appears to be supported, but does VCM editor recognize the vehicle and the software in it? That's a question for the support team I would think.
    28,265
    Quote Originally Posted by Dr scott Diabolical View Post
    https://support.hptuners.com/
    Thanks Tunerpro. That's exactly what I was trying to say and determine. I grew up tuning with a timing light and a dwell meter. So I'm not familiar with all of the new terminology yet.
    Oh HELL YEAH!
    Bill Henn (HP Tuners)
    May 3, 2022, 1:35 PM CDT
    Thank you for contacting HP Tuners support Scott
    In speaking with our GM engineer we can confirm that we do support your application, it uses a shared ecm and operating system to some other application already listed on our supported vehicle list.
    Based on your vin number we were able to look up your vehicles info and confirm it is supported.PXL_20220503_223653047[1].jpg
    13,564
    Yours looks a lot cleaner than mine.
    I have a 2003 same color with a 3.1 V6 in it. Only has 89,000 miles but has some mean piston slap and it also made friends with a guard rail two winters ago down the drivers side. But for $600 is was worth the money and now it's only cost me $1,500ish total to fix it up and have a decent beater car.
    Aug 2016
    386
