I'm trying to get the VVE table dialed in on my 2011 Corvette with a Vortech supercharger. I've been following the Goat Rope Garage youtube setup for dialing in the VVE table. I've got my wideband plugged into my driver's side factory O2 port and disconnected the factory sensor. I have DFCO disabled by increasing the enable RPM to 8,000.
The problem I'm seeing is that on coast down the wideband is reading off the charts lean. At this point it isn't bucking or anything. I increased the injector minimum pulse width to 1ms to make sure the injectors are spitting out fuel. I can see the mixture go rich a bit as the VVE table wants the injectors to go below that 1ms pulse width, then all of a sudden it goes off the chart lean for quite a while.
Any ideas on what is going on here? If the injectors are working the only thing I can think of is that the mixture is not igniting for some reason. Any help or comments would be appreciated. Thanks. Below is the log and tune file.
