Hi like so many of these posts I am another beginner. I have completed a rebuild on my L76 which has included DOD delete the new cam is a Lunati Duration @.050" 212/218 0.531 lift 113 LSA. my goal is to get the car running well enough to safely bed in the new rings and bearings before getting it Dyno tuned. So far I have turned off the DOD and increased the idle sped by 75RPM.
I initially had bank 1 O2 sensor codes and P071/P074 I switched sides with them tightened the inlet a little and the both rears started working but front bank1 reads low and lean bank 1 code , I discovered a a broken ground and corrected it, o2 sensor started working, I reset LTFT and the voltage picked up all looked ok.
I started it the next day bank 1 LTFT and STFT around 25% bank 1 O2 sensor output between 20 and 48 mv Bank 2 sensor working fine. I reset LTFT VCM scanner and O2 sensor rights itself and the LTFT appears to work properly.
My next step is to replace the Injector o-ring seals in case they leak when cold. I am open to suggestions on what else could be causing this problem. I have tried to upload my most recent log file.
22-05-02 12-10-44.hpl
