My Spark plugs are white ash..... Chemically correct (14.7 A/F Ratio) is Tan carbon....
How do I correct this?
Change the 02 sensor voltage map?
HP Tuner says this :
' [ECM] 12530 - O2 Sensor B1 R/L vs. Airflow Mode: These tables define the Rich/Lean switching voltages for the O2 sensor in relation to Airflow Mode. '
Air Flow Mode 0 480.907732028808
Air Flow Mode 2 480.907732028808
Air Flow Mode 4 480.907732028808
Air Flow Mode 6 480.907732028808
Air Flow Mode 8 480.907732028808
Air Flow Mode 10 490.895502106264
Air Flow Mode 12 525.95461339856
Air Flow Mode 14 525.95461339856
Air Flow Mode 16 525.95461339856
Leaner is less Voltage....
So.... I do a little more Voltage... To go a little Richer.
Or what do I do?
2001 GMC Sierra 2500HD 6.0 L Vortec Gasoline 4L80E 3.78 Rear End.
Thanks....
