Results 1 to 4 of 4
Thread: used ecu /ecm from one to anouther
    May 2022
    3
    new to hp tuners and any kind of tuning. i got a used ecu/ecm from a suburban and wanting to put it in a 2011 camaro the camaro doesnt have a ecu/ecm at the moment due to a theft what needs or should be done to work in the car if it will work at all any help will be great thanks
    13,565
    What year is the suburban computer from?
    In short the donor computer would need to be flashed with the VIN/OS that is on the Camaro for it to work correctly. Using a GM tool will flash all segments of the calibration so that it starts life as the correct file with hopefully no issues at all.
    May 2022
    3
    2011
    13,565
    Okay, I'd still have it flashed with a GM tool to the correct VIN on the vehicle.
