Results 1 to 11 of 11
Thread: LS3 swapped Fireberd idle issues
    Nov 2019
    Bahrain
    77
    So the LS3 is up and running all good. I have two issues.
    1) When I set dynamic airflow to 400 RPM the car idles awesome BUT does not respond properly to throttle, back fire to the intake.
    2) When I set dynamic airflow to 8000 RPM the car picks up throttle perfect and all is good except cranking and coming to a stop. it dies instantly and struggles to run.
    The car has a mild cam, 92mm throttle body(cable), LS3 maf sensor and adapter harness
    can some one shed some light to what should I now? which parameter is upsetting the car.
    This car has been tuned previously on cam only LS1 and what i did just make the car run or start on LS3.
    I tried adding/removing fuel from VE table with no use, altered many of the throttle settings under idle tab with no use.
    Aug 2009
    Calibrating
    3,374
    VE and MAF just need to be dialed in
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Aug 2009
    Calibrating
    3,374
    If using card style MAF and using ls1 tune you need to add about 30% to entire MAF abs should be much closer
    14 Gen 5 Viper
    Nov 2019
    Bahrain
    77
    Yes, it is card style maf.
    Thanks for the input, i will give it a shot and update the post
    Aug 2008
    Chicago
    98
    In addition to what Ben said, i noticed a few things you need to change, the cylinder volume is wrong for an LS3, assuming you are using LS3 injectors? The data looks similar, but is incorrect, the short pulse limit is at 0.8. Why is the timing table so low? It is at 10 degrees when you're trying to accelerate, you need to add a lot of timing in the light load regions.
    2000 WS6 Trans Am LS3, Tick Performance Stage 2 cam, ARH 1 7/8" Headers, FLT Level 6 4L60e, Circle D 5c Launching on a 200K 10 Bolt
    2001 Camaro SS M6 Black on Black
    Aug 2008
    Chicago
    98
    Also, you are logging too many pids in the scanner, only log what you need.
    Nov 2019
    Bahrain
    77
    Quote Originally Posted by 01SLPSSM6 View Post
    I've read that changing the cylinder volume will miss-up the fueling and its the incorrect way to compensate for the fueling.
    I've used the green excel sheet to dial in the injectors and it didn't mentioned anything about the short pulse limit. What should short pulse limit be at??
    as for the timing its just a base starting point, i just need to get the car to start and idle properly & i will dial in the rest later.
    Aug 2008
    Chicago
    98
    Quote Originally Posted by akalshaikh View Post
    The correct cylinder volume is important in a P01/P59 pcm. It uses cylinder volume for speed density calculations, actual cylinder airmass, etc
    Short pulse limit should be 4.000ms
    Add timing now, thats too low, use a stock table and copy over the low load regions for now and blend it.
    Nov 2019
    Bahrain
    77
    Thanks for the input, will do that tomorrow and keep you posted.
    Nov 2019
    Bahrain
    77
    UPDATE:
    So i have dynamic set to 3000 RPM. Car idles perfect and done some changes to VE table but still needs to be improved though.
    Tried running on MAF only and set the dynamic airflow to 500 the car idles much better then yesterday but still bogging when i try to rev it. Once it picks up RPM its better.
    STFT shows rich and when i try to remove fuel it boggs way more and back fires to the intake again. I did add 30% fuel and it was better but again STFTs show rich
    I keep CL off and just force it on from VCM scanner.
    the car runs fine now but it need much more tuning to get her dialed in. waiting for the wideband.
    Attached is the last tune (IAC and lower idle), other tune files where i tried dynamic airflow & some logs.
    Nov 2019
    Bahrain
    77
    any inputs?
    Shall i just dial in the maf and i'll be good or do i have some issues other areas?
