Results 1 to 6 of 6
Thread: 4l80e soft shift with a hd2 transgo shift kit
    Apr 2016
    3
    I?ve done 2 different transmission?s and have the same issue 2-3 doesn?t shift hard. I have the separator plate drilled for drag race 1-2 and 3-4 are like a rock but 2-3 in both transmissions are soft. I have the clutch packs w/o the wave/spring plate and the correct gap between the pressure plate and the pack. I have checked the psi and it runs on the higher side of the range that the book gives. I did not change the band on either transmission. Not sure what I need to do to get it to shift harder
    Dec 2019
    MS
    567
    Getting a 4l80E to have a Firm 2-3 can be tricky sometimes.
    What torque converter do you run in them?
    Apr 2016
    3
    It has a Kevlar clutch stock stall and diameter. No programming for the transmission. I didn?t think it would be a programming issue. I don?t have debris in the pan the oil is clean
    Advanced Tuner Shrek's Avatar
    Nov 2011
    753
    Quote Originally Posted by pro439 View Post
    So, you are running the OEM stock transmission calibration - while also using many aftermarket hard parts - and wondering why it does not magically shift the way you would like it to ?
    One of the best areas, for people new to tuning to begin, is with changes to the transmission calibration. With a 4-speed automatic, a small number of changes can greatly improve the "seat-of-the-pants" shift feel - often dramatically changing the overall driving experience.
    Tuning the transmission calibration is required to maximize the benefits of your hard parts upgrade.
    Apr 2016
    3
    So you can?t do it alone with hard parts? I don?t have anything to tweak the program and have never done any programming. I wasn?t sure if I had missed something in the transmission. What would you use to program? I?ve done programming on big trucks-tweaking. I thought I missed something that I?m not aware of. I appreciate your responses
    405
    2,326
    Well you are on HP Tuners forum. How about HP Tuners.
