Lots of info coming, trying to be as thorough as possible here so bear with me...TLDR at the bottom.
Definitely a noob tuner as well, but I'm just trying to get to stock right now.
2009 CTSV manual - new to me, supposed to be stock.
Seemed pretty decent when I drove it for the first week or so, I've driven 2 other stock/basically stock CTSV's and it felt very similar.
Stock airbox, filter, stock mufflers, but has like 1.5" holes drilled at the rear axle where you would put a cutout, sounds decent actually.
It feels like a normal stock car, driving like an old person, but a slight "pulsing" in power throughout the RPM WOT, and very flat feeling at like 25% throttle.
Went to do some testing, because I can't leave anything alone, and while I was testing I noticed it was getting a ton of KR, like up to 12* in some cases!
See tune "V original tune"
Bad side note - I have been beating on the car for about a week now, 6700-6900 WOT shifts cause I didn't know it wasn't stock and it felt decent...whoops!
So then I went back to the house and looked up a stock 09 V manual tune on the repository and noticed that my car was somewhat tuned, but not a whole lot was done.
Also looked up a 2010 V manual, and a ZL1 manual, but they're all a little different, so I'm not 100% on what I should have in my stock file - went with best judgement.
Went on another run but didn't save the log, basically just as bad, still lots of KR, I think it was like 8* now.
Makes no sense that its got that much knock on a stock tune with 93 octane...
Decided to do some basic maintenance, pulled a plug and it had TR6 gapped at like .042, has newer looking MSD wires.
Put in NGK TR7IX, gapped at like .033 now based on what I saw online for a stock car, seemed like most people said .030-035
Also pulled valve covers to make sure I didn't break anything in my high RPM shifts, all looks and feels normal, but I didn't pull pushrods out.
Next day...
I tried to be somewhat consistent in my runs, everything is with a minor cool down while I looked at logs and played with the tune, then a 3rd gear pull...may have to scroll a bit to find the WOT, sorry.
I know my IAT2's are a little high, I plan to flush and burp the supercharger coolant tomorrow, along with checking out those single digit misfires.
Went back out and got a log, car felt just ok.
See log "Log 1, 3rd gear pull..."
Still getting lots of KR, so I googled stock V/LSA timing, and seems like most people said 18-24* so I shot for that range and started tuning.
After a few runs, trying to get rid of the KR, I ended up taking out around 10* out of it, and doing some minor PE tuning to hope rule out any fueling issues (I have a wideband in another car, just not in the V yet)
Still has some KR (I've read that some is ok on stockish stuff), running around 20* throughout the run. Definitely felt slower to me, and still some minor pulsing throughout the RPM range.
See log "Log 2, v newest tune..."
See tune "New stock V tune, version 4"
Then for fun, I loaded up the original tune into the car to see how it felt.
See log "Log 3 - original tune..."
Had less KR with the new plugs but still getting a lot...also its asking for 31.5*!!! WTF! That's way too high right???
Car felt "normal" to me, still some slight pulsing in the power but feels like I think a stock V would pull.
I'm starting to wonder if more is done to this car and it was returned to stock or what...
The only other weird things I've found so far are 2 header bolts were missing, but turned out they were broken off when I tried to put another one in. Front driver and rear passenger. Don't think it had headers at one point, but kinda weird.
It also has the front brake duct pulled out on the driver side for a fender well intake, but the intake on the car is totally stock.
I also did some comparative analysis on the logs where I ran the same speed over the few days, about 42-70mph, and timed the differences based on the tunes.
IAT's were only like 4* difference
Boost calculated by barometric minus MAP is 8.6psi, so that should be in line with stock
When the car was how I picked it up, TR6 plugs, original tune, lots of KR, "Log 1", it took 7.578 seconds to go 42-90mph in 3rd
When I ran the car with the same original tune, TR7IX plugs, less KR but still quite a bit "Log 2", it took 6.245 seconds to go 42-90mph in 3rd
When I put the stock tune in, with my adjustments to try to get it to stop showing KR, "Log 3", I had to compare a slightly different speed range to the above runs.
Log 3, 42-70mph, 4.349 seconds.
Comparatively, Log 2 did that in 3.539 seconds.
The car is considerably slower! I also have VCM scanner measuring engine torque, I'm sure this isn't a correct number...but it says there's like 45ftlb difference between these runs, backing up that its slower/makes less power as I felt.
Bottom line...TLDR
WHY is my car so SLOW on what I believe should be stock timing (22ish?) my slowest log
Why does the car pull like a normal V on nearly 32* of timing WOT and get a bunch of KR? I don't wanna blow this heap up.
I should have logged injector duty cycle, so I'll add that to the list.
Tomorrow I'll check plugs/wires again for those single digit misfires
Coolant flush for IAT2 temps
I'll work on getting my wideband out of my other car and put on this one so I can check that side.
Only conspiracy theory I have is maybe the car was ran with E85 or something but totally stock otherwise and that's why the original tune has so much timing?
Any thoughts are greatly appreciated! I'm super frustrated with the car
