Hey guys,
I'm hoping there's an answer here. I'm trying to get my fans working using a C6 PWM fan controller. The ECU is an E38 set up for a 2015 Z28 LS7. The tune file was set up for discrete fan control as I received it. I tried copying over all the fan settings from one of the C6 cars I used to own, but the fans do not operate.
After doing some searching here, it seems a segment swap might be the answer. I was going to try it with one of my C6 files, but the segment swap option is grayed out. I'm guessing that means something isn't compatible? I found a 2015 SS sedan tune files that look to be compatible, so I was going to try that. I have zero experience with this, and don't want to cause any permanent damage or brick the ECU. The main OS is the same between my tune file and the SS file, so I'm hoping the segment swap will work.
Files in question are attached. Thanks
2015 SS manual.hpt
Andy's LS7 speartech file.hpt
