E38 ecu on my '14 camaro ls3.
In my tune, I changed stoich to 14.1 because of the E10 91 octane we have here in California.
I recently installed my aem wideband and am tuning the stock engine to ensure I have the right channels, graphs and logging setup before I start throwing mods at the engine.
I would like confirmation I have everything set up properly? In my datalog, cruising, my AFR commanded is 14.09, WB EQ ratio is .99Lambda , Equivalence Ratio Commanded is also .999Lambda.
In my graph, I am logging EQ Ratio Error [Math] x MAF hertz
The error reported will be accurate for my stoich settings and I won't have any issues with I turn on my factory narrowbands again, will I?
Screenshot attached of my layout as well as tune and datalog.
Thanks!
