Hi,
I have a LS1 with 4L65E in a fairly light Ford -32 hot rod. The transmission tune is all stock from a Camaro Z28 2002. The issue I have is when I go from neutral to drive at 650 rpm idle it drives forward too much. I have to push hard on the brake to prevent it from jumping forward.
Is there some parameter I can prevent it from pushing hard forward at idle?
PS
I'm experienced with the HP Tuner, but only at the engine side.
DS
Thank you!
