Results 1 to 14 of 14
Thread: Tundra SAI
    Dec 2019
    Tundra SAI
    Does anyone on here know if Secondary air can be disabled on Toyotas through Hpt. have google searched and used forum search to no avail. this is one of the many reasons I bought my mpvi2 and any help would be appreciated TIA.
    Mar 2019
    Ennis, TX
    87
    Absolutely.
    Apr 2019
    3
    Could you elaborate? I have a 2007 Tundra with that is in limited power mode due to SAI codes. I have unchecked all of the SAI codes which keeps the check engine light out, but it is still in limited power mode. I am not sure what I am missing.
    Apr 2019
    3
    Changed values under (airflow-electronic throttle-sec air-fault a-fault b). No more limited throttle.
    Mar 2019
    Ennis, TX
    87
    Quote Originally Posted by workshop bot View Post
    Does anyone know if the sai valves need to be blocked off? And if the check engine light comes on or can be disabled?
    Mar 2019
    Ennis, TX
    87
    Quote Originally Posted by rockchip View Post
    If you're disabling the SAI System and the "limp mode", I'd strongly encourage you to use a block off plate.
    Perfect thanks! I assume that the valves under the intake are what should be blocked off? Anything else?
    Baltimore, Md
    1,011
    What are these SAI system your talking about?
    Truck has supercharger on it, I assume need to raise TPS to 86 or so so its not torque limiting?
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
    "secondary air injection" it seems to be like the old '70's air pumps designed to scam the emissions testing equipment
    What did you change the values to?
    For no throttle intervention due to SAI fault, increase the values in the Engine -> Airflow -> Electronic Throttle -> Limits -> Sec Air Fault -> Air Fault A/B tables to a value equal to or greater than the values in Engine -> Airflow -> Electronic Throttle -> Max Rotation -> Max Angle/Max Angle B (86 degrees in a stock file).
    Thanks, slow stock! That's what I figured, but wanted to double check. Hopefully this will help the next guy who does a search.
    Sep 2019
    Tennessee
    4
    So did this work .
    I have a 08 Tundra 4x4 4.7
