I have tuned my MAF and VVE tables then zeroed fuel trims and turned everything back on. The problem is now when Im logging EQ ratio error it appears to be slightly lean all the time and my fuel trims seem to be pulling fuel? I have a few things I think may be the issue but thought I would ask someone more experienced. I have my virtual flex fuel sensor disabled but the fuel here ( Canada ) is all up to 10% ethanol. can I adjust my Stioch table to say 7% ethanol so the fuel trims can handle the rest? Also when Im in boost my Eq ratio still stays at 1 is that OK? I thought I should be rich while in boost. when Im in PE my EQ ratio look good .78 ish but when I roll into the throttle or go up a hill and come into boost Im not in PE? Then I also noticed my delivered torque maxes out at 640 and stays there? I attached my most recent Log and tune files. If anyone could have a look and give me some pointers it would be appreciated. thanks
