Results 1 to 2 of 2
Thread: Flex fuel
    Flex fuel
    Would you lean or richen PE Table to start? E45, the table still applies right? It just uses the current alcohol percentage in the fuel, then applies the math? Thanks
    13,565
    I go leaner with more alcohol content. On my truck I ask for 12.4-12.5AFR on gas and lean it out to 12.8-12.9 at higher than 60% alcohol content.
    Off hand I forget my exact numbers I used in both EQ ratio's.
