Would you lean or richen PE Table to start? E45, the table still applies right? It just uses the current alcohol percentage in the fuel, then applies the math? Thanks
I go leaner with more alcohol content. On my truck I ask for 12.4-12.5AFR on gas and lean it out to 12.8-12.9 at higher than 60% alcohol content.
Off hand I forget my exact numbers I used in both EQ ratio's.
