i am having a problem under high load part throttle, like if you are in second gear and slow down for a yield sign and then when you get back on throttle it seems to break up a bit unless you step further into it or let off a bit. if i hold it in that position it will turn on throttle pedal light and i will lose all pedal until i restart it. it also set a p061a code [level 2 torque performance]. i have logged this issue and included log in this post. any help would be appreciated.partthrottleissue.hpl
