Results 1 to 2 of 2
Thread: 2010 procharged srt problem
    Mar 2022
    8
    i am having a problem under high load part throttle, like if you are in second gear and slow down for a yield sign and then when you get back on throttle it seems to break up a bit unless you step further into it or let off a bit. if i hold it in that position it will turn on throttle pedal light and i will lose all pedal until i restart it. it also set a p061a code [level 2 torque performance]. i have logged this issue and included log in this post. any help would be appreciated.partthrottleissue.hpl
    Mar 2021
    Pompano Beach FL
    263
    Get with your tuner he should be able to clear it up. Its in the tune
    www.n2speed.com
    http://www.amp4x4.com
    [email protected]
    Dodge And GM Tuning Suppport
    Diablosport CMR | HP Tuners
