Ive about had it with this crap. I have been chasing my tail all week, spent many hours getting nowhere.
I have an LS swapped BRZ. It is a 5.3 HO with a decent sized cam (Comp Cams 54-477-11) supporting valvetrain, ID1000 injectors, Dorman intake manifold with a 7875 turbo.
I have tried custom VVE zones, I am currently working with cts-v zones though. The ecu I have is an E38 from a truck so I dont have a custom OS option. I am forced OL, doing a SD only tune. MAF is failed, logging my wideband against commanded EQ (math option in scanner).
I went out and did a nice long log, even held the brake to sweep through as many map cells as I can. The first pic with green is from the long log. Smooth throttle transitions. I then took that data and pasted % by half to the VVE. Then the pic with all the red is the result I got. WTF its been going back and forth like this all week. I must be doing something wrong. I cant imagine the VVE getting thrown that far off with 1 change.
But then, I then flashed back to the tune where I originally got that nice long log with green and now its lean everywhere! No misfires are reported, not an exhaust leak, its definitely running lean.
I need help.
