I believe that it is in the Editor, as when I look at someone's posted file it automatically shows their VVE at whatever scaling I had been using last.
I have this half baked theory that it is a good idea for someone tuning a NA engine to at least look at their VVE on a boosted scaling. Sometimes you can have a smooth VVE up to 100 kpa, but when you look at the boost level areas, it goes wonky. Maybe it does not matter since the engine never sees these areas, but it may be causing some of the individual coefficients to be skewed in an unnatural way to make the table fit. Say for example, more weighting should be going on the MAP or MAP2 coefficient but instead it is getting made up on the Constant or a combination of other coefficients.
Same could be said for the other end of the table, below the default 400 rpm starting point. When I first started messing with VVE, some changes I made would negatively affect startup. When I expanded the table, I saw that while the 400 rpm column was staying consistent, it was severely skewing it down low at 100 rpm. In this case maybe the RPM2 was being changed more than it should, instead of another coefficient or combination of coefficients.
