Results 1 to 9 of 9
Thread: Corvette OS for ECM swap
    Oct 2019
    Finland
    7
    I'm swapping 2010+ ECM to my 2006 A6 Corvette. Is there some OS that is considered best OS to use? Or are all 2010-2013 Corvette OS so similar that it doesn't matter what to use?
    7,619
    Since you can't make this change using HP Tuners if you want all the segments fully programmed, how would you go about getting any OS other than the most-recent release on GM SPS?
    Oct 2019
    Finland
    7
    You are right. Question is what year VIN to use. I checked some VIN and OS seems to be different 2010-2013.
    7,619
    SPS will only give you the most recent calibration for whatever VIN you feed it, you cannot pick an older one.
    7,619
    And, um, are you sure you can get a 2010 OS to talk to all the 2006 modules in your car?
    Oct 2019
    Finland
    7
    I'm not 100% sure about anything before I have tested it by myself. But I have been told that it will work and it been done many times so I'm willing to try. I will report how it went
    And I understand that SPS will give me only the newest OS according to VIN. But I checked that different years have different OS. So the question really is what year VIN to use? Or does it really matter.
    7,619
    But isn't there a comms protocol difference breakpoint in mid-2009? Late ECM won't talk to an early TCM and vice-versa.
    The OS IDs are different because they are different years, GM rarely used the same OS on multiple years.
    Can I ask the reason for wanting to do this at all?
    7,619
    Why I ask is, if it's because your current OS doesn't have a 2bar OS available... then just get it updated.
    Oct 2019
    Finland
    7
    I have the 2 bar OS so it is not the reason. With newer E38 I can scale spark table airmass, get integrator delay for better O2 adjustment and there is more parameters to log for idle tuning etc.
    But I got ECM swapped and everything works. It is from 2011 Silverado and I flashed it to Corvette OS with SPS.
