Results 1 to 14 of 14
Thread: LS 5.3 / sloppy cam stage 2 head studs 102 trim turbo and innercooler 80lbs ev6 injec
    May 2022
    Klamath Falls Oregon
    8
    5.3 motor: gen 3
    E1840 sloppy cam stage 2
    1997-2007 rpm range 2200-5400
    Hydrau roller
    .585" intake V.L.
    .585"Exhaust V.L.
    Advertised intake Dur 283 Degree
    Advertised Exhaust Dur 286 degree
    intake duration @ .050:228 Degree
    Exhaust duration @ .050 230 Degree
    lobe sep 112 degree
    intake centerline 108 degree
    Note not use with AFM/DOD
    Headstuds
    3 layer Head gasket
    Hiflo oil pump
    new timing gears and chain.
    80 LBS EV6 injectors
    Truck plastic intake stock throttle body
    102 trim turbo for cummins
    innercooler
    I have 02 sens in but i have disable in the tune
    Idle set 975rpm
    Tune im building is scattered I am so new but im trying.
    I have increased my fuel injectors to 80LBS
    and upped my idle since it runs now in SD mode i disable MAF
    I want to make it idle and hold boost
    I have 4l85e auto trans from 2000 camaro
    i can start it runs but rev up it dips down and dies
    7,546
    Injector data is more than just the flow rate, and that's all you've changed in the file.
    May 2022
    8
    like i said very new to the tuning I am not sure what area i need to modify and what it should look like
    ~Robert
    Would you be able to alter the tables I need and reattach file to this thread I would appreciate the help
    and this way if you have noted on the reply what areas you adjusted then i can see with the compare file function.
    Thanks in advance if you can do so but if not i understand people are busy.
    ~Robert
    7,546
    Injector data is specific to each part number. If your injectors didn't come with all the data in the format a GM PCM/ECM needs, well... I wouldn't say they are worthless, because I guess you could sell them on to someone else.
    You also have a VE table that got filled with placeholder data when the custom OS was applied. Same for the MAP sensor linear & offset - if your actual sensor doesn't use the default placeholder values of 200/10.33, that needs to be corrected as well.
    May 2022
    8
    Log file before i changed to 2 bar
    Here was a log of some things changed but it was not setup for 2 bar yet.
    May 2022
    8
    acdelco 217-303
    SET OF 8 Upgrade Bosch EV6 Fuel Injectors For 1996 TO 2000 Chevrolet K3500 Suburban 7.4L V8
    Manufacturer Part Number : 17109596
    *Please match the compatibility chart before purchase*
    1996 TO 2000 GMC K2500 7.4L
    1996 TO 2000 GMC K2500 Suburban 7.4L
    1996 TO 2000 GMC K3500 7.4L
    1996 TO 2000 GMC C2500 Suburban 7.4L
    1996 TO 2000 GMC C2500 7.4L
    1996 TO 2000 GMC Savana 3500 7.4L
    1996 TO 2000 GMC C3500 7.4L
    1996 TO 2000 GMC P3500 7.4L
    1996 TO 2000 Chevrolet K2500 7.4L
    1996 TO 2000 Chevrolet C2500 Suburban 7.4L
    1996 TO 2000 Chevrolet C3500 7.4L
    1996 TO 2000 Chevrolet C3500HD 7.4L
    1996 TO 2000 Chevrolet K3500 7.4L
    1996 TO 2000 Chevrolet Express 3500 7.4L
    1996 TO 2000 Chevrolet P30 7.4L
    Specifications
    Typical Flow Rate in LB per hour: 80 LBS/HR @ 48 PSI
    Typical Flow Rate in LB per hour: 76 LBS/HR @ 43.5 PSI
    Typical Flow Rate in CC per minute: 840 CC/min @ 48 PSI
    Typical Flow Rate in CC per minute: 800 CC/min @ 43.5 PSI
    Actual flow rate of your injectors may vary, but will be matched together
    Resistance: 10 ohms (High Impedance, High Resistance)
    Voltage: 8-15 Volts, nominal 13.5 Volts
    Amperage: 1.0 Amps
    Pressure: Min 30 PSIG / Max 100 PSIG
    O-Rings Included: Yes, on the injectors
    Injector Body Design: Metal and composite plastic
    Fuel Delivery: Upgraded single fuel delivery nozzle for superior fuel atomization
    7,546
    Yeah, but all those applications use a 22.2lb injector, not 80lb. If they're modified then none of the stock data applies any more. If they are aftermarket higher-flow injectors with the same outside dimensions as 17109596 then none of the data applies any more. Plus, that early Vortec PCM doesn't have the injector tables you'd need to convert the data over to P01/P59 format.
    May 2022
    8
    So what would you recommend i do honestly I am lost.
    7,546
    If you really truly need injectors that'll support ~1000hp then you will need to buy real aftermarket injectors from a reputable company that supplies full data with their parts. This is expensive. But then again considering everything else needed at that level, how much the injectors cost is pretty insignificant.
    But if your real-world (not fantasy 'one of these days...') power goals are more realistic, like 650-700 (at the crank), then there are ~50lb factory GM injectors, with all the data in stock tune files, that you can get for very cheap.
    May 2022
    8
    Thank you i will see about purchasing $40-50 lbs injectors with data specs
    ~Robert
    13,559
    Most guys buy GEN 4 injectors from a flex fuel 6.0 or 6.2 truck from 2007.5+. Those are 50 or 52lb/hr and don't cost alot.
    The data can be found in stock files from similar vehicles and then there is a spreadsheet floating around here that lets you convert the GEN 4 data into GEN 3 data.
    7,546
    Axis labels in the spreadsheet don't line up with the late 127lb ECMs.
    400 416 432 448 464 480
    408 428 448 468 488
    13,559
    Close enough is good enough?
    Dec 2019
    MS
    568
    What turbo is that?
    Ive had good luck with Deatschwerks, Fuel injector connection and Fuel injector clinic on injectors with good data.
