Results 1 to 6 of 6
Thread: 16 Silverado 6l80 not shifting
    May 2021
    25
    Hey,
    Flashing a friends truck for a DOD delete and some minor transmission tweaks but every time I write the truck and try to reset the adapts the truck won?t select a gear. If I rewrite the calibration but don?t try to reset the adapts everything works normally. Am I doing something wrong?
    13,565
    That's kinda odd. I can flash my 2016's PCM/TCM and go into the scanner prior to starting the truck to reset the adapts and have it work no problem. Just did it about 2 weeks ago too.
    Dec 2019
    MS
    567
    Ive had that happen a couple times. I just stop doing the Adapt Reset.
    SoCal
    1,562
    Did you do the "Fast Learn" after the adapts reset?
    May 2021
    25
    Initially I just tried the adapts reset. I did try the the fast learn but didn’t realize there was such a procedure to it. When it failed the fast learn I still couldn’t get it to select a gear. Next step at this point I guess is to try again but complete the fast learn properly and see if it makes a difference.
    Jul 2020
    VIC Australia
    1,157
    If you have access to GDS2 and a MDI or VCX Nano you can try resetting via that route. Will be pretty obvious where the problem lies after trying that.
