Results 1 to 10 of 10
Thread: 04 silverado tune and no closed loop. O2 not responding
    May 2022
    Nancy KY
    8
    I have an 04 5.3 base tune with manual trans segment swap and o2 sensors will not read so won?t go into closed loop. Other ecu I have works fine in o2 dept. Had other issues with that ecu is why I changed. Any idea what could be happening?
    7,451
    Log file so we can see if it's setting any codes, and tune file so if there aren't any codes we can see if the codes have been turned off. Need something to look at.
    13,533
    Never seen a manual segment swap actually work.
    May 2022
    Nancy KY
    8
    I cannot figure out how to get files loaded here to share. I was able to email them to a friend but can?t figure out how to load them here
    May 2022
    Nancy KY
    8
    What issue have you seen in doing so? I used an 04 5.3 auto OS and segment swapped trans from 4.8 manual. It seemed to work.
    7,451
    May 2022
    Nancy KY
    8
    Thank you very much. I will post them when I get in this evening
    May 2022
    Nancy KY
    8
    13,533
    450mv on the o2 sensors means they are either unplugged or they have a power/ground problem with them.
    Can also try flashing back to a non segment swapped file to see if anything changes.
    May 2022
    Nancy KY
    8
    Not unplugged and no power or ground issue. I can plug the old ecu back in and they work properly. I went into the OS portion and modified to MAF and rewrote it and now they are working but still not properly imo.
