Originally Posted by
engineermike
I just took a quick 1 minute look at your tune and noticed that the only IMRC-open mapped points you have enabled are 14 and 21, and those have identical cam timing. The only mapped points it CAN choose are 14 or 21 and it had to pick one since they are defined to the same coordinate. That part is working exactly as you told it to. I suggest you read and learn more before you break something.
Edit: Its still in vct fuel economy mode at wot, so that part needs to be addressed. That said, it?s following the fuel economy distance table which sends it to a certain mapped point location (that is not mp14). But since that mapped point is disabled then it?s forced to use the only enabled point (14). Disabling a mapped point doesn?t prevent it from sending the cams to that location, but it does prevent it from using the calibration data associated with that point.
