Results 1 to 5 of 5
Thread: LT4 Gen5 No Throttle when started
    Apr 2018
    5
    Hello, I have a basically stock 2017 Corvette Swap LT4 Gen 5 (except for DOD Delete, no variable camshaft, added a cam phase limiter) that's mated to an automatic TCI6X transmission. I have it installed in an 84 Monte Carlo. For the following problem, I have tried to use the original Automatic Transmission tune and also a Manual transmission tune. Both have similar results.
    The engine starts and will idle, but it has no throttle when started and goes into reduced power mode. I've had a few good folks help me that I contacted from this forum, but still I cannot get the throttle to change once the engine starts. The pedal works when the key is on, 0-100%. Also, when the key is on, the throttle will open and close with the pedal, but only up to about 40+%. Using the special functions in the VCM Scanner, it will over-ride the throttle from -100%, but again, only when the key is on.
    Attached is the manual transmission tune I am currently using and a log. Any help in the right direction is greatly appreciated! Thank you.
    Manual Trans Tune-220519-1.hpt
    Manual Tune- First Start 220519-1.hpl
    Apr 2018
    5
    Cancel this- I figured it out...
    Aug 2009
    Calibrating
    3,372
    Glad you figured it out!! Now let’s tune this rig
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Oct 2022
    4
    Would you please post your solution
    Quote Originally Posted by 59rah View Post
    I am having the same issue with no throtttle response. Engine starts and idles but no throttle.
    I have yet to see a solution posted after someone figures it out. It would be very helpful.
    Apr 2018
    5
    The ETC was in Limp mode i.e. ETC Disabled. This is why the accelerator would not work. There could be many reasons for this. For me, I had spliced the TPS signal to my TCI Transmission control module from the accelerator pedal primary signal. The ECU did not like this. I removed the splice and engine came out of limp mode. To get the TPS Signal to the transmission, I used the throttle signal wire on the Position signal 2 (Pin 2, ECU X1-34), not the primary signal 1 (Pin 5, X1-15) from the accelerator pedal. I hope this helps!
