Results 1 to 14 of 14
Thread: s550 fourth shift point issue
    Hi
    please i need help for fix fourth gear its shift early at 6600
    also everytime i git p0300 and many missfire code for every car i was tune 18 intake manifold
    mods: big cai, im 18, headers long with x pipe
    thank you
    Feb 2012
    TEXAS
    634
    Quote Originally Posted by ghost ksa View Post
    Hi
    gear.hpl
    6 trany with add 5%.hpt
    thank you
    I have mine setup like this.
    Quote Originally Posted by mstang_man View Post
    i will try and back to you
    Feb 2017
    TX
    761
    You're commanding that shift. Use these values in the bottom rows of your Sport shift map.
    Quote Originally Posted by Thatwhite5.0 View Post
    only oss change
    Jan 2013
    Hawaii
    2,101
    thatwhite5.0 is right you are commanding around a 6800RPM shift 4th to 5th.
    I would keep rows 13 and 14 the same values as thatwhite5.0 also shows. It just makes the small adjustments per gear you may need to make to get it to WOT shift at the exact RPM you want it to.
    Oct 2016
    Poland
    1,737
    Well shift schedule is not used at WOT...adjusting it to 9000 rpm wont change a thing. Not a good advice.
    You are short shifting because you still have some limiters to take care...
    Jan 2013
    Hawaii
    2,101
    He has his WOT shift map at 7800, and the base shift map is set to 6778, maybe a little higher or lower depending on physical TCC slip/ anticipaction timing. Its going to use the one thats significantly lower.. the one to command the shift first.
    Nice that you can use a very general "limiters to take care" statement and play it off like its helpful to anyone tho. Just stick to your usual base tune peddling.
    TC limit in 4th is 127.50 ,this is where the forced upshift is occurring
    Oct 2016
    Poland
    1,737
    Quote Originally Posted by murfie View Post
    I respect your opinion but you were wrong at the end of the day...nothing to do with shift schedule as its being ignored in WOT state.
    TC is forcing the upshift. A few things can do that: TC, accel rate, torque, abuse, truncation...you can leave schedule stock and
    still have nice crisp 8000 rpm shifts. My tunes have no problem with that and I rarely adjust shift schedules.
    Feb 2016
    482
    I have a good tune for u
    Jan 2013
    Hawaii
    2,101
    The log indicates the vehicle speed to be a slow rise fom 117- 130MPH when the 4-5 shift happens. if 127.5 was the limit I would expect the TC to shift before it got to that. Its a very performance conservative, with an exaggerated responce, system to kill wheel spin. Instead RPM is at ~6750 which is the value in the shift schedule table.
    Good luck selling your tunes.
    Oct 2016
    Poland
    1,737
    I sell few tunes a month no worries here
    No go and modify a schedule to verify that you are wrong. You only talk, no fast projects cars ever made by you...
    Ok i will try what murfie and thatwhite5.0 told me and i will back
