Thread: Remote start issue
    May 2022
    Remote start issue
    I have a customer with remote start on an 03 silverado it uses and obd2 jumper and even after plug-in to the factory gm port I still can pull the file it starts the process the timer climbs up over 400 mins to download and then says time out any help would be greatly appreciated
    Advanced Tuner dhoagland's Avatar
    Jun 2015
    Aubrey TX
    890
    If I understand you are having issues reading the tune file.
    Is there a fuse to a Remote start Controller?
    Thinking it could be like some after market radios require fuse pulling because the interfered with communication?
    Can you communicate with the scanner, and other obd2 readers?
    2,742
    It's common with 03-06 OBS trucks.
    Pull both radio fuses. They are under hood. You might have to read with the "high speed mode" box unchecked.
    Tuner at PCMofnc.com
    Jun 2021
    4
    This happens to me everytime I flash , what I have found is make sure everything is off- radio , ac, dome lights, headlights, etc... Turn key on and wait for about 45 sec then try to flash . Most of the time it works first try , and others like 3rd or 4th try .
