Hi all,
I put an a/a intercooled centri on my 05 GT last year. I've gone to a few dyno shops, but it's tough to find someone who tunes 3V's with HPT.
I'm new to tuning, this mustang being the first car I've tuning. I have read Don Lasota's "THE ULTIMATE FORD HP TUNERS EFI TUNING GUIDE", which was great. I'm looking for some help & suggestions, to go along with my reading and trial and error. Any recommendation on additional PID's to log, histograms set ups, tuning workflow etc. would be hugely appreciated!
Set up info
Vortec V2si
A/A intercooled
Tial Q50 BOV, vented to atmosphere
Blow through MAF, HPX5000
47lb FRPP injectors
400LPH Fuel pump with wiring upgrade
-8an fuel lines, billet fuel rails
CMCP delete plates
AEM wideband, logged via analog input #1
AEM Boost Gauge, logged via analog input #2
MPVI2 w/ pro feature set
Tune Info
-5* timing (for safety while I adjust the MAF curve)
Adaptive WOT - Disabled
STFT - Enabled
LTFT - Enabled
Base Fuel Map .8λ @ WOT
DFCO - disabled
I posted a WOT log, a driving log, and my current tune file. Do they help answer these questions?
1) I use the STFT and EQ err histograms to edit my MAF curve. The MAF voltage rows in the histogram is set up to match the MAF voltage rows in VCM Editor. I copy the EQ err %, expand the lowest recorded value all the way down, and highest recorded value all the way up, then use the "multiply by % - half" command in VCM editor. I've found the EQ err and STFT do not match. STFT seems more accurate at lower loads and MAF voltages, and EQ err seems more accurate during WOT pulls at high load. Should I use STFT to adjust the lower part of the MAF curve and EQ err for the high part?
2) Using the above histograms and workflow, multiplying by % - half after each log, I expected to EQ error and STFT to close in closer to 0 with each log. I've done probably 40-50 pulls, and it doesn't seem to be getting any better. If you look at "R23 First WOT", my EQ err is almost all under 1%, with a high of 2.5%. "R23 2nd WOT" was logged after using log #1's data and multiplying by % - half, but my EQ err is way off, 4-16%. This has been common, I have decent runs and horrible runs, with no pattern I can see. Is there something I am doing wrong here? Should I be applying my correction factors differently?
3) During WOT pulls the car is surging. I noticed in "R23 First WOT" the MAF lb/min data log looked off. Rather than smoothly increasing with revs, it oscillates. I think the surging is due to the "squiggly" MAF reading. For "R23 2nd WOT" I logged TPS voltage and cam angles, thinking airflow over the MAF might be the culprit of the variable reading. TPS voltage was consistent, but cam angle seemed to vary with the MAF reading. Would faulty VCS solenoids alter cam timing enough to effect the MAF reading and cause a surge? Or is the squiggly MAF reading causing the VCT to alter the cam angle? Might it be belt slip at the blower? Any other ideas what it could be?
Long winded, but trying to provide enough details. Any help would be hugely appreciated!
